Editing and Deleting Invite Codes
Invite codes that you have created will be listed in the Invite Codes screen. (Select Invite Codes from the sidebar menu.)
If your web browser window is large enough, each invite code will have the following two icons in the Actions column:
Select this icon to edit the invite code. |
Select this icon to delete the invite code. |
HIDDEN ACTIONS: If your web browser window is not very wide, you may not see the two icons above. Instead, there will be a blue plus sign to the left of the invite code. Select this icon to display the remaining options.
